It is currently Thu Aug 07, 2025 11:05 pm
PostPosted: Mon Jun 15, 2009 12:00 pm
Last Name: Sollod
What's the best way to use Micromesh, circular motion or back and forth with the grain?
www.swiftcreekguitars.com
PostPosted: Mon Jun 15, 2009 12:28 pm
Well, when I have used it, I go with the grain, and I've been pleased with the results.
Joe
PostPosted: Mon Jun 15, 2009 12:29 pm
Both...
I use it with the grain when using it dry. I use it in circular motion when wet sanding. Both have provided wonderfully smooth and uniformly polished surfaces.
PostPosted: Mon Jun 15, 2009 1:12 pm
If hand sanding than strainght lines if using the orbital pads the the random orbit is fine as long as you go through the progression.
If you did not know that micromesh was available in 5" RO pads go to http://www.micro-surface.com
PostPosted: Mon Jun 15, 2009 4:22 pm
Is this on bare wood or finish. If on the finish, what would going with the grain direction do. At that point grain direction doesn't have anything to do with it. It should be a smooth surface.
PostPosted: Mon Jun 15, 2009 10:26 pm
Zach is right. If it's the finish, there is no grain, although crisscrossing your sanding will be more efficient. The only reason to go with the grain when sanding the finish is if you plan on leaving some scratches in. Of course, on my final buffing I do go with the grain because even though the scratches are so fine that they can't be seen with the naked eye, I know they are there and I figure I might as well have them go with the grain of the wood. I really don't think it matters though.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
Users browsing this forum: No registered users and 41 guests
